Truck vs F-Body 4L60E
Old Aug 15, 2003 | 01:07 AM
IslandTahoe's Avatar
Default Truck vs F-Body 4L60E
Is there any difference between the F-Body and 2WD Truck A4 transmissions? Are they interchangeable?
Old Aug 15, 2003 | 01:22 AM
RED2K's Avatar
Default Re: Truck vs F-Body 4L60E
I am pretty sure they are. I think they might have a different clutch pack though.
Old Aug 15, 2003 | 02:02 AM
If you are talking about the 4l60e, the only difference is the torque converters are different sizes from f-body to truck. The bellhousing I also beleive is just a little different, being a two part for the trucks, and a single with removable bottom panel for the f-body. I forget for sure, was looking into that originally last year!
Old Aug 15, 2003 | 11:55 AM
so a transgo shift kit for the f-body 4L60E would work just fine for the truck 4L60E?
Old Aug 15, 2003 | 12:59 PM
Yeah, it should, I noticed when I looked into shift kits, that they listed different part numbers for the shift kit if it was either a truck, or the f-body. I guess the transmission shift points are completely different between the two vehicles. I believe that the f-body kit is better if you have programmed your truck to shift like a car.
I hope I am not wrong on this, can't really remember everything that I found out when I was looking for a performance build.
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
