is it the battery or the starter???
Old Aug 15, 2003 | 12:22 PM
onyx's Avatar
14 Second Truck Club
Default is it the battery or the starter???
ever since i got the truck it has done this. the battery shows up in the message canter (i dont know if they all do this when the ignition is turned). the truck has no problem starting cold, as in, its been sitting all night.
if i try to start it again after, say, i went into the store and came back out, it takes exactly 3 times, everytime to get it started again. whats up with this?...
Old Aug 15, 2003 | 12:26 PM
GTO Forum Director
Default Re: is it the battery or the starter???
The battery symbol shows up in the message center upon ignition feed. That's normal.
Are you saying though that your truck needs three attempts sometimes before it'll turn over?
If so, check;
1) Battery connections
2) Starter may be hanging up. When it does this, grab a mallot, hammer, flashlight end, something that can deliver a solid albeit not crushing blow to the starter housing. This will knock the armature of the starter loose from teh brushes along the wall that it got hung on.
Old Aug 15, 2003 | 12:27 PM
Deckhand's Avatar
i get the message as well on ignition, but I just have to it over once, and it starts up...
Old Aug 15, 2003 | 12:33 PM
onyx's Avatar
where is this located.... dduuuuurhhhhrrrrr....
i'm serious though.
Old Aug 15, 2003 | 01:03 PM
GTO Forum Director
The starter?
It is on the passenger side of the truck, you'll have to get underneath. The starter is a cylindrical motor that is mounted next to the oil pan and into the front of the transmission bellhousing.
RustyD
May 23, 2016 07:04 PM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
kalikid06
20
Oct 13, 2015 07:37 AM
Slammed silverado
Sep 28, 2015 06:14 PM
