Truck Problem
Old Jun 16, 2005 | 04:19 PM
Sleepy53's Avatar
If you cleaned th K&N some of the oil could of gotten on your maf screen causing it to run worse, but I dunno (just my .02)
Old Jun 17, 2005 | 08:09 AM
BobbyBa's Avatar
It was doing it before I did that.Good Suggestions Any more
Old Jun 17, 2005 | 08:52 AM
sd155racer's Avatar
Coolant temp. sensor
Old Jun 17, 2005 | 09:33 AM
BlackLM7's Avatar
Does your 2000 truck have stock wheels/tires?
Old Jun 17, 2005 | 09:46 AM
JERRY2500's Avatar
14 Second Truck Club
I forgot about that one. I had it happen to another truck i had. But it was the t-stat. The temp would get just high enough to drop the timing and just kill the power.
Old Jun 17, 2005 | 10:07 AM
11SECSS's Avatar
10 Second Club
My 05 SS only get 13.8 mpg no matter what i do.....you should check for codes even if the light is not on.
Old Jun 17, 2005 | 11:47 AM
BobbyBa's Avatar
It does have the stock wheels with 75 series tires.Can you ohms out the temp sensor to see if it is bad?I will see about get a scanner and checking for codes.
Old Jun 27, 2005 | 09:48 AM
BobbyBa's Avatar
Just wanted to let everyone know what was wrong with the truck.I checked for vacuum leaks and did not find one.I checked the pvc valve and it looked brand new.No oil on it at all.I reinstall and made sure it seated.I have put around 200 miles on it this weekend and I still have a little over half of a tank.I am going to drive it all week and see what happens.It looks like that was the fix.I was only getting about 250 to 275 mile per tankfull before.
Old Jun 28, 2005 | 12:01 PM
4SHONGO's Avatar
Open the exhaust
Old Jun 28, 2005 | 12:04 PM
1FUNZ71's Avatar
Lets us know how it turns out
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Suburban2500
Jul 13, 2015 09:57 AM
