Truck doesn't start after cam install help..
Old Oct 28, 2013 | 02:00 PM
  #21
Yukon04's Avatar
Crank sensor wire is pulled out......
Old Oct 28, 2013 | 02:01 PM
  #22
TXsilverado's Avatar
not going to start without that sensor plug it in and fire it up.
Old Oct 28, 2013 | 03:02 PM
  #23
Yukon04's Avatar
A wire was cut... From that connector
Old Oct 28, 2013 | 08:11 PM
  #24
running now?
Old Oct 28, 2013 | 08:13 PM
  #25
Yukon04's Avatar
It is... Two problems one fans come on instantly two runs like ****... I installed a gt7 cam I figured it would be ok without a tune for now since it's not a big cam guess not.
Old Oct 28, 2013 | 08:59 PM
  #26
what size is that cam? i cant keep up with all of the cam pet names.
Old Oct 28, 2013 | 09:39 PM
  #27
Yukon04's Avatar
208/230 550/552 121lsa
Old Oct 28, 2013 | 11:45 PM
  #28
cdub81's Avatar
On the grounds, there is one that connects on the pass top side of block...
Then the drivers side back of block by bell housing
On the fan/idle shitty, could be as simple as idle airflow adjustment since you've changed cam/heads etc. Yea you can run it but it needs some tuning
Old Nov 9, 2013 | 01:33 PM
  #29
RangerDan's Avatar
I just did a TSP 220R (220/220 .581/.581 112 LSA) swap and a DOD delete, no tune but it heats up and runs hot now because its running way lean. I won't be driving it any length of time or distance until I get it tuned just to save that kind of heat shock on the internals.
Dan
all_individual
Oct 10, 2015 10:09 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
all_individual
Jul 13, 2015 11:01 AM
chevy1224
Jul 13, 2015 07:50 AM
