Truck doesn't start after cam install help..
Old Oct 28, 2013 | 10:40 AM
Yukon04's Avatar
Default Truck doesn't start after cam install help..
More heads are better than one so after swapping cam head gaskets, oil pump swap and valve springs the truck doesn't start.... It turns over and over no fire... Need some ideas it say for a week with the battery disconnected and the heads were disassembled and cleaned.
Old Oct 28, 2013 | 11:03 AM
Whitecrewcab's Avatar
Sounds like something wasn't plugged back in after the install. Gotta make sure all the sensors are plugged up
Old Oct 28, 2013 | 11:53 AM
Yukon04's Avatar
Maybe now it's daylight and I can see
Old Oct 28, 2013 | 12:10 PM
TXsilverado's Avatar
check for spark. if no spark, id look for connections to the coil packs (main harness) plug wires then cam and crank sensor. look for the easy stuff first.
Old Oct 28, 2013 | 12:13 PM
Yukon04's Avatar
The cam and crank sensor can be found on back of block correct?
Old Oct 28, 2013 | 12:15 PM
Yukon04's Avatar
Just pulled a couple plugs gaps are correct they are dry...
depends on the year of the truck. cam sensor is most likely on top of the engine behind the intake, and the crank is on the passenger side of the block just above the starter. if you have a gen IV engine the cam sensor will be on the front of the timing chain covor.
make sure all of your grounds behind the heads are connected too.
Old Oct 28, 2013 | 12:33 PM
Yukon04's Avatar
What if the cam sensor and crank go out of sync
Old Oct 28, 2013 | 12:50 PM
did you go dot to dot on the cam gear install?
Old Oct 28, 2013 | 12:55 PM
Yukon04's Avatar
Reason I say during the cam swap I had to wait on the correct head studs while apart I hooked up computer to get my doors locked and unlocked.... Pretty sure that was a bad idea
