Truck doesn't start after cam install help..
Old Oct 28, 2013 | 12:55 PM
Yukon04's Avatar
Yes crank 12 and cam 6
Old Oct 28, 2013 | 01:05 PM
TXsilverado's Avatar
dont think cam and crank sensor can get out of sink as long as you have the timing events set correctly, which you did correctly from your install description. it's going to be something silly keeping it from starting.
do you have HP tuners? it may need a security relearn. it will usually fire off for 1 second when needing a relearn though.
Old Oct 28, 2013 | 01:06 PM
Yukon04's Avatar
Is there any grounds that attach to the heads?
Old Oct 28, 2013 | 01:07 PM
Yukon04's Avatar
I feel I remember attaching a ground to the block back there that may have belonged to a head????
yes. both of them on the back side. it's been a while since i've done a swap, but i think theres only a strap to the firewall on the drivers side and then 2 or 3 wires to the passenger side.
Old Oct 28, 2013 | 01:14 PM
Yukon04's Avatar
I'm finding they go on the block... Can someone confirm?
Old Oct 28, 2013 | 01:34 PM
Yukon04's Avatar
Anyone?
Old Oct 28, 2013 | 01:45 PM
as long as they are to either the head or the block they should fine. i found it easiest to connect them to the back of the head.
Old Oct 28, 2013 | 01:48 PM
Yukon04's Avatar
They are connected.... Next?
Old Oct 28, 2013 | 02:00 PM
did you check for spark?
