truck dies....
when i crank it up first thing in the morning it starts fine, but later on the day, i crank it and it tries to turn on but dies, then i try it again, and i have to give it gas in order for it to start. also when im at a stop light it wants to die... what can it be ??? fuel regulator ???
My 92 did the same thing when the fuel pump started going south. It got progresivly worse. It was fine at highway speeds but accelerateing and ideling it had problems. I got a new pump and it fixed it right up. I would try what nightrunner said and maybe changing the fuel filter first tho. That is just my two cents. Hope you get it going good again.
yeah, ill try to clean the throttle body, and check the fuel regulator also. i already changed the fuel filter and cleaned the injectors, and i doubt its the fuel pump, but that might be it. thanks for the help.
