Trouble with truck
Old Oct 18, 2005 | 07:08 PM
  #21
In order to handle alot of boost first of all you need arp head studs second some sce titan head gaskets are the best IMO and good ****. There are some f-body guys running 12-15 psi of boost then there are guys spraying 250 shots on them and having good luck. Im not sure about the boost/nitrou combo though.
so the t rex cam would be good on a 8.7 to 1 compresion motor without FI
Old Oct 18, 2005 | 08:42 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why would you want a low compression motor if you werent going to go forced induction? If you go FI then get something in the 8.5:1-9:1 range and something with a wider lsa around 114 if oyu are going to use the bottle then I would go with a bit narrower lsa so you would have better na performance and whatever you get with the nitrous is a bonus.
Old Oct 18, 2005 | 09:40 PM
  #23
so 110 lsa would be ok for nitrous
Old Oct 18, 2005 | 09:50 PM
  #24
1slow01Z71's Avatar
Theengine wont respond as well as it would with a cam with a 114lsa but your na performance will be better and the torque curve will start lower. I want badass na performance and whatever I get with the nitrous is a plus. I want it to be strong without a power adder. Plus a cam with a 112lsa like the cam in my sig will have a badass idle.
Old Oct 18, 2005 | 09:55 PM
  #25
that is why i like this cam so it would be ok to use nitrous with this cam but if i was going with FI down the road i should get a higher lsa cam just to be safe right. or do you think i will be ok with this one the most boost i will probably go with is 8psi or even maybe a 150 shot of nitrous or i might just stay all na
Old Oct 18, 2005 | 10:07 PM
  #26
1slow01Z71's Avatar
The t-rex will work fine for nitrous, like I said before it just wont respond as well to it as a 114lsa cam but will ahve a nasty idle and give really good na performance. The cam will work for FI but just not as well.
Old Oct 18, 2005 | 10:12 PM
  #27
what type of pistons are u using with your setup and which dart heads are you using if u dont mind me asking.
Old Oct 18, 2005 | 10:15 PM
  #28
1slow01Z71's Avatar
Using the flat top eagle piston with a -2cc valve notches in it and the dart ls1 heads but Im getting the combustion chambers cleaned up and enlarged to 66cc to get bring the CR back down to a streetable level.
GrooveCityZ71
Aug 31, 2015 12:05 PM
wrb002
Aug 31, 2015 12:00 PM
lxcoupe
Jul 21, 2015 02:12 AM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
