Trouble with truck
Old Oct 13, 2005 | 08:15 AM
Default Trouble with truck
i came out of the driveway last night i goosed it so the tires would turn over then let out. coasted a few feet and their was a loud pop then the truck died wont start back. took it back home to the garage and tried to turn the motor over by hand but it will only go so far then catch. any suggestions on what this could be. i am going to start taking her apart tomorrow. do you think it could be a dropped valve or a broken piston rod or what? please help in any way. or is it telling me that it is time for a 408?
Old Oct 13, 2005 | 09:52 AM
mattrem's Avatar
Could be several different things, How many miles do you have?
Old Oct 13, 2005 | 10:13 AM
zippy's Avatar
i'd be looking for a dropped valve or broken timing chain.
Old Oct 13, 2005 | 10:15 AM
mattrem's Avatar
timing chain, is a real possibity
Old Oct 13, 2005 | 10:26 AM
it has about 8k on the motor
Old Oct 13, 2005 | 10:45 AM
mattrem's Avatar
Hard to say could be alot of things, you might not see a broken valve with just the valvecovers off, unless a keeper or retainer failed. The head of the valve could have broke off though and leave the stem in the spring. If the timing chain broke then there could be bent valves.
If its locked up it could be a rod. or a piece of the valves stuck in there some where.
Old Oct 13, 2005 | 11:25 AM
when you it catches it has a little metal clang noise to it.
Old Oct 13, 2005 | 11:29 AM
Fogle07's Avatar
****** the front cover off and take a look. it dont take just little bit of time.
Old Oct 13, 2005 | 02:55 PM
when it popped it then house something like a glass shattering should then smoke came out from underneath the truck but not from the exhaust
Old Oct 13, 2005 | 03:02 PM
mattrem's Avatar
Are you sure its in the motor? Maybe the trans or TQ?
