Trouble with truck
Old Oct 13, 2005 | 03:20 PM
no i am not it will be saturday before i can take it apart. but why would the motor not turn over for if it was the trans.
Old Oct 17, 2005 | 08:40 AM
I broke two rods in three place shaddered 2 pistons and put a whole in the side of the block it even put a few small marks on my cam so it looks like it is time for the 408 after all.
what would be the best cam for the 408 stroker. i am going with the eagle kit.
Old Oct 17, 2005 | 11:31 AM
OrlandoFL4.8's Avatar
what would be the best cam for the 408 stroker. i am going the eagle kit.
I would be interested to know what caused this? Did your timing chain slip, From what it sounds, I mean its not like you were running the hell outa it pulling outta your driveway- did you bump the nitrous?.
Old Oct 17, 2005 | 11:42 AM
SBChevrolet's Avatar
WOW Thats alot of **** from a quick bump of the gas
Old Oct 17, 2005 | 11:45 AM
no nitrous was off i say it was from all of the hotrodding that it had been in before in the prior days the pistons had some melted spot on them from the nitrous.
Old Oct 17, 2005 | 02:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Check my sig IMO thats what you need you are lighter than me you could even go with the T-Rex cam that is a bit bigger. Im not too worried about streetability since I will be getting a better in Feb. so Ill just have to deal with the gas sucker till then.
Old Oct 18, 2005 | 09:01 AM
who makes the t-rex cam
Old Oct 18, 2005 | 09:11 AM
jerome's Avatar
thunder racing
Old Oct 18, 2005 | 04:24 PM
so do you think this cam would be ok with nos or FI and 8.7to 1 compression or should i get the higher compression setup. how much boost and nos can the eagle 408 kit hold with stock heads or even dart heads.
Old Oct 18, 2005 | 05:16 PM
1slow01Z71's Avatar
In order to handle alot of boost first of all you need arp head studs second some sce titan head gaskets are the best IMO and good ****. There are some f-body guys running 12-15 psi of boost then there are guys spraying 250 shots on them and having good luck. Im not sure about the boost/nitrou combo though.
