Trick Flow Timing Chain Damper
So I got my lm7 back from the machine shop. Installed the cam last night and went to install the ls2 timing chain. Installed the timing chain damper per trick flows instructions, but the chain rests and is slightly tight on one side of the damper but not the other. While looking at the alignment it looks like either the damper bracket is machines wrong, or the damper is. Anyone else running these? What does the spacing look between the chain and damper on yours? I’m at work now but I’ll post some pics of the chain clearance later.
Resting and tight on drivers side.
Clearance on passenger side
Thanks for posting up! I have the same Trick Flow TFS-K30675600 kit and I am sure other will find this helpful.
I see the slight difference in the dampener. I was not aware it was offset to 1 side and needs to be clocked correctly.
I went back and re-read the directions and it makes no mention of this.
