Transmission and rearend rebuild
Old May 10, 2003 | 10:42 AM
Default Transmission and rearend rebuild
Made a costly trip to the track took out transmission and rearend at the same time.Any suggestions on how to make both the transmission and rearend live with 500lbs/ft of torque.I'm starting the rebuilds monday.
Old May 10, 2003 | 02:12 PM
Hit Man X's Avatar
Default Re: Transmission and rearend rebuild
What all did you break? I'd suppose the G80 in the rear and prolly the input shaft and drum or sun gear shell in the trans...Got any video?
Anyway... the rear end is pretty easy to beef up:
1. Eaton Positraction
2. T/A Performance Stud Girdle
3. Forged Axles (Strange, Moser, etc.)
Find my post about the 4L60E build up in the search area of this board.
Good luck?
Old May 10, 2003 | 03:12 PM
A better question is what did I not break?Trashed about everything both planetaries, drum,filled a Yank 3ooo with metal broken ring gear broken differential.But the axles are ok
Old May 10, 2003 | 03:40 PM
Hit Man X's Avatar
How the hell did you do that? Massive wheel hop or something?
Here is that write up:
https://ls1tech.com/threads/showflat...rue#Post268061
That should help a bunch. Good luck!
Old May 10, 2003 | 05:13 PM
No wheelhop to much bite from the Drag T/As,3000rpm launch and tons of supercharged horsepower.
Old May 10, 2003 | 05:31 PM
creederado's Avatar
That Sucks, Was is the first run of the day and did you have any warning?, Tranny slipping more and more or the rear not locking up?
Old May 10, 2003 | 05:37 PM
Hit Man X's Avatar
Oh hell thats why...drag radials on a stock 8.5" w/ G80! LOL. I thought it broke in 4Hi somehow.
Old May 10, 2003 | 06:37 PM
No warning at all a good burnout,one short hop,stage,launch bang.I'n going with every hardened internal part I can find and a Eaton posi with a TA stud kit I'm debating over a 4.10 or 3.73.
Old May 10, 2003 | 10:11 PM
creederado's Avatar
From what I remember Toms Differential came highly recommended in the past.
http;//www.tomsdifferentials.com/tomc.htm
I'm looking into upgraded my factory g80 to 4:10 and the Eaton. Especially now!
Whitt with the 26 drag radials and your stock rearend gears what is the new ratio? Would staying with 3.73 with your tires be better. I'm running 28(track) 29(street) and I think 4:10 would help.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
jscherbs
Sep 30, 2015 07:54 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
