Transgo help and ?'s
Old Feb 17, 2004 | 02:47 PM
lm7's Avatar
lm7
Default Transgo help and ?'s
okay i have a standard cab, 6.0 swap, Lt's, ATi Procharger at 9lbs, EDit.... i had an FLP 4l60 which i blew the front pump on after a bad installation ( converter never seated properly) after that the tranny was never the same went out completly in 3 weeks of daily driving no racing at all....anyway thats out and the stock 4l60 is taking its place...i know my stock one wouldn't last to long with the boost so im buying a Transgo( the one with the video)... now which vette servos do i need to buy? and what should i tell the transmission shop on how to install the kit? i want this tranny to last me until this summer when ill be putting another fresh FLP in it and maybe a stall,...for now stock will do...since money is short.....
Old Feb 17, 2004 | 03:01 PM
mudz5.3's Avatar
The servo's you can get from
http://www.superior-transmission.co..._superservo.htm
http://www.superior-transmission.co...super_servo.htm
These are the same servo's I have, waiting to be installed. Not sure what to tell the guy as I haven't done it but someone will post in. I am sure if he is competent, he will know what to do. As far as the washers on the servo's, I believe no washers on either will give good firm shifts. If you want a little more, then add a washer to the 1-2 servo. Correct me if I am wrong fellas.
SloSVO
Nov 22, 2020 07:34 PM
Wolftrk99
Dec 3, 2015 08:12 PM
jtphelps289
Sep 29, 2015 12:00 PM
EmmerichLSx
Sep 20, 2015 02:09 PM
lycominghunter
Aug 15, 2015 12:26 PM
