blowing fuses?
Old Feb 15, 2004 | 04:50 PM
Tokez420's Avatar
Question blowing fuses?
my uncle has a 99 4x4 suburban
he keeps blowing the T case fuse right when u install new one. the 4x4 fuse is okay. but it blows the T case fuse right away. any ideas?
Old Feb 15, 2004 | 06:06 PM
NovaTime's Avatar
sounds like a wiring problem.
Old Feb 16, 2004 | 12:17 AM
eallanboggs's Avatar
A HOT wire with no load before it reaches ground (RETURN) causes a fuse to blow. HOT wires need a load so work can be done. That's why they're HOT. If your HOT wire is BYPASSING its' load and heading straight for ground the fuse will blow every time. Is there some function on the vehicle that is INOPERATIVE when the fuse is blown. Check that circuit for a pinched wire or a wire with worn or chaffed insulation. Have you done some work in that area recently? Go back over your work. You'll need a schematic diagram to trace out the circuit from the source (fuse panel). This must be a HOT wire that is touching ground (bare metal surface) where is shouldn't. Circuits do have to eventually reach ground, but they better have a load in the circuit before they do or you will find yourself with the problem you are describing.
Old Feb 17, 2004 | 03:05 PM
Tokez420's Avatar
great info! i'll print this out and give it to my uncle
thanx a lot.
Idryfly5
Sep 2, 2022 08:55 PM
dantheman1540
Feb 24, 2016 09:56 PM
00loudchevy
Dec 3, 2015 05:54 PM
turbo6c3
Oct 5, 2015 06:11 PM
TrickTurbo
Sep 23, 2015 08:41 PM
