transgo advise
Old Nov 4, 2003 | 08:22 AM
Default transgo advise
I remember reading about the transgo that hitmanx installed in his truck. He said something about wanting to remove a washer because it was to rough. I am installing my transgo and corvette servo, but i need some advice from you guys that have done it.
Thanks.
Old Nov 4, 2003 | 08:55 AM
ThunderZ28's Avatar
12 Second Club
whats the questions
i have the adjustable transgo with a vette servo
Old Nov 4, 2003 | 08:58 AM
Originally Posted by 01 Thunder
whats the questions
how many washers did you go with on the 2nd acumulator
Old Nov 4, 2003 | 09:05 AM
ThunderZ28's Avatar
12 Second Club
sorry man i asnwered in the other post about cottmans
Old Nov 4, 2003 | 10:46 AM
Hit Man X's Avatar
Thanks.
Hi, when I had my TransGo installed I also had the billet apply servos installed at the same time. Also I had an aluminum 1-2 piston put in place of the junk plastic one that was in my trans.
Well with the billet servos and the single washer in my 1-2 accumulator I could bark my 285 AT's at ~4000rpms! The billet apply servos VASTLY improve the load capacity on the 2-4 band. Basically make the shifts a lot quicker/firmer...sorta like adding washers but the billet servos clean up all the shifts.
When you install the TransGo and 'Vette servo, I recommend NO washers in the 1-2 accumulator. The washers everyone talks about only effect the 1-2 upshift. No washers will keep all the shifts about the same firmness.
I hope that helps...ask me more if you need to!
Old Nov 4, 2003 | 10:50 AM
ThunderZ28's Avatar
12 Second Club
hey hitman you ever make it to HRP. i know its on the other side of town from you, but we need to hook up sometime. would like to check out your truck.
Old Nov 4, 2003 | 11:04 AM
Hit Man X's Avatar
I am gonna try to make it to that Winter Cruise if someone would tell me the physical address of it! Must be a
I wuz going to bring the ol' Blue Oval out there (hey I am more proud of that than my Z71 due to all the mods) but I suppose I can bring my Z there. It is laughably slow so don't expect anything too great from it.
I am wondering if your trans shifts too hard...and that's causing the problems you are encountering.
Old Nov 4, 2003 | 12:46 PM
ThunderZ28's Avatar
12 Second Club
well hes soposed to let me know what it was. might have to put some torque management back in.lol
we'll see
Old Nov 4, 2003 | 12:55 PM
Hit Man X's Avatar
we'll see
Hrm...ditch all those washers, get your line pressure back to stock too! Get a billet servo!
Old Nov 4, 2003 | 01:08 PM
Quik's Avatar
5 year bitches!
i do know if your line pressure is too high youll have problems thats what happened
with my stang.
heres a question what are you guys referring to with torque management?
