Trans Go and billet servo's with a stall?
Old Feb 11, 2004 | 12:46 PM
Gustin's Avatar
Question Trans Go and billet servo's with a stall?
I am torn...
I am fixing to get a 3200 stall converter for my Z71. I want to do a tranny upgrade while I am installing the converter. I have installed trans go's before and they work great. I have read about many options you can do to these 4l60's. I want firm shifts but not neck snapping. So what kind of combination will suit?
Thanks,
Sean
Old Feb 11, 2004 | 12:50 PM
BigKID's Avatar
I have a TT3000, transgo, vette servo with one washer in the 1-2 accumulator. The washer will be comming out when I do a fluid change this weekend because it shifts too hard for my tastes. All other shifts are great though.
Old Feb 11, 2004 | 03:39 PM
mudz5.3's Avatar
Gustin you peckerhead, why don't you answer your phone!! Anyway, hows the truck? Do you ever tow with it, like the camaro? Are you gonna go with Yank or a Vig? Well if you tow, stick to the tt3k, if not, then I am sure you know what to do. I just got a transgo and billet servo's. Haven't installed them yet, but working on it. Hows the cam running with the nos?
jz
Old Feb 11, 2004 | 08:34 PM
Gustin's Avatar
jz
Sorry James I must have missed your call did you leave a message? This offshore thing is whooping up on me now. I will give you a shout when I get back on land. I am going to get that new Yank 3200 10" converter that is capable of towing 7K pounds. Where can I get this billet servo.
You can see the New best ET for the 67 in the sig. The N20 shut off at the 1k ft mark via window switch because I ran out of gear
Thanks for the info Bigkid.
Sean
Old Feb 11, 2004 | 09:00 PM
mudz5.3's Avatar
Sean
Nice times, what gears you running in that beast? You have a nine in that right? Do I hear a nodular swap coming? Anyway, check here for the kit http://www.tbyrne.com/truckcatalog.html
The servo's you can get from
http://www.superior-transmission.com...superservo.htm
http://www.superior-transmission.com...uper_servo.htm
Not sure if it will be a link, if not, just cut and paste. That will take you directly to what you need, well its what I have anyway and seems to be the right stuff. Hows the truck running now a days? Any time to get to the track with it yet? Knowing you, you have, but no times posted in sig for the truck.
edit: oh and the new proyanks are supposed to handle that but most people don't think it will, prolly toast the trans if you tow alot. You could just get a big *** cooler with a fan if needed.
Later,
jz
Old Feb 11, 2004 | 09:14 PM
Gustin's Avatar
Later,
jz
I have 4.56's in the 67 with 28" ET streets. I am going to a 30" true slick for the next time at the track. It was all over the place through 1st and 2nd gear. Made that track look like a river.
I havent ran the truck yet. Mods on the truck now is: 5 inch Rancho suspension lift, 16 x 10 Mickey T Classic 2's with 33's, Sir michaels roll pan, Tahoe grille with putco inserts, Gibson catback, K&N FIPK, ASP underdrive pulley, Meziere Electric waterpump, Electric fans and coming soon when I get back to land: AS&M long tOObs, cam, and converter with tranny upgrades.
Thanks for the info on the servos and kit!
Sean
Old Feb 11, 2004 | 09:17 PM
mudz5.3's Avatar
I havent ran the truck yet. Mods on the truck now is: 5 inch Rancho suspension lift, 16 x 10 Mickey T Classic 2's with 33's, Sir michaels roll pan, Tahoe grille with putco inserts, K&N FIPK, ASP underdrive pulley, Meziere Electric waterpump, Electric fans and coming soon when I get back to land: AS&M long tOObs, cam, and converter with tranny upgrades.
Sean
What happened to that billet grille I installed for you? Sounds like a nice truck though, good luck when you run. Oh and KEEP IN TOUCH!!
Oh hows tubby and your fam doin. Too personal, just pm. Later
jz
Old Feb 11, 2004 | 10:37 PM
Gustin's Avatar
jz
You are thinking of the GMC I use to have. I will keep in touch. Hollar at you soon.
Sean
bighouse
Sep 27, 2015 12:37 AM
lycominghunter
Aug 15, 2015 12:26 PM
lawhitediamante
Aug 12, 2015 12:14 PM
Ferocity02
Aug 7, 2015 08:50 PM
