Tranny problem?
Old Apr 8, 2004 | 01:55 PM
01Blackerado's Avatar
Do any of you techs in here know how much hp the stock 4l60e can hold b4 it destroys itself???
Old Apr 8, 2004 | 02:07 PM
Does know if this will help
On the older body style trucks - the same thing happened
There was a TSB about it
If you removed the drive shaft - then filled the rear of the
yoke (about .5 to 1" )(not the entire thing)
with a heavy grease like cv grease -
the bump will go away.
I did it to many trucks
Supposedly on rapid decel the output shaft and yoke
come to rest in a slight bind - the bump is the yoke after the brake
is released.
Dont know if this true for these trucks - but worked for me on the OBS.
FYI
Old Apr 8, 2004 | 05:34 PM
LS1NOVA's Avatar
That lube does work but I heard it doesnt do the transfer case clutches any good when it gets hot and mixes with the fluid. I would say it needs a nickle plated slip
yoke to correct the famous bump/clunk.
Old Apr 8, 2004 | 09:53 PM
Hit Man X's Avatar
Maybe 375hp before the 3-4 pack goes. If you don't slip the clutches or band, you'll begin to break internals in short order with hard launches.
Old Apr 9, 2004 | 03:47 PM
Thanks Hit, much appreciated!! So should i go for some servo work then or do you think i should wait. I am planning on getting that L5 tranny from FLP anyway so...
Old Apr 9, 2004 | 04:29 PM
Hit Man X's Avatar
Well considering you're pretty much stock w/ a few bolt-ons, get a TransGo and servos in there to see how long it'll last. I bet a long time.
I'm going to see how far a TransGo + billets can take a stock internal 4L60E. I have NO TqMgt and it's fine still...granted I dont' have a lot of power but I'm not stock either.
Wolftrk99
Dec 3, 2015 08:12 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
