Tranny problem?
12 Second Club
Say I'm at a stop light, I let off the brake and idle off the line I feel a bump. It has been doing this alot lately. Where its becoming very noticible. What is it? The tranny is shifting fine. Even if I give it alittle gas istead of idle off the line it still does it.
Back in the day when I had my Hypertech, mine would do this too.
Its like it wouldn't always shift back into first gear when coming to a stop.
Then, when I would barely touch the gas, it would shift to first from second and cause a big bump from the drivetrain.
Sometimes it would do it before I even hit the gas when the light turned green. I would just be sitting there and it would just, thump, shift into first from second, even though I was already stopped at the red light.....weird.
Did it just stop one day? What did you do to fix it?
It didn't do it all the time....just every once in a while.
I have no clue....it was a '99 Sierra
12 Second Club
Is it like a shudder you are experiencing?
I had this very same problem, took it to the dealer and found a burnt band from 2-4 accumulator and rod hanging up on the case. They ended up rebuilding the tranny under warranty. I also had the HTPP3 and they did ask if i had reprogrammed the pcm, but i removed the program before i took it down there!
Mine only did it after the programmer as well.......hmmmmm?
