Track Results On 16" Wheels
Originally Posted by Flyer
Where in TX are you? What track did you go to?
Originally Posted by whitt1
I'm guessing that the gap between 2nd and 3rd gear felt a lot better too.Now wth a stall you can put that beast into the low 13s with some 1.8 60' times.
.I am looking at a stall, shift kit and headers within the year, and believe it or not I may stop there, although a nice cam sure is tempting.
14 Second Truck Club
Originally Posted by smooth sierra
going from a 31" tire to a 26" tire might have had something to do with it as well
to really compare apples to apples you would need the same diameter tire and leave the tailgate on. I would think the actual difference would be .1-.2 at most for the 20's although I have no idea how heavy the factory 20's are. I think tire diameter was your biggest friend here. It's equivalent to stuffing some 4.10's in the rear. good for 1/4 mile bad for mileage.
i think the VHO should have come with 4.10's from the factory. it's tough to say which was better, the lighter weight of the wheels or the shorter tire. i'd be guessing the main difference was the tire height. switching to a stall and a 4.10 gear those numbers would be much closer to each other.
The main difference is weight and where it's located,the the further out the weight is located from the center of the wheel the greater the inertia and the greater the power used to accelarate that mass.It also takes more braking force to stop.
AHelm3
Apr 8, 2016 07:51 AM
GMCtrk
Dec 18, 2015 04:47 PM
