TR6's question
I ordered some TR6's from summit and they sent me TR6 V-power's. The middle electrode is v-shaped instead of flat.
Are all TR6's V-power, or is there a regular type too?
Anyone running these with boost?
hey black, those will be fine. I have been runing them for a long time and they work swell. just double check the gap and check them every oil change. you will like them. how's that new converter working out. I am so jelous.
run away from the NGK TR's if you are spraying or s/c ing. try some R5671A-6's or 7's if you can find them. they are a gasketed NGK V-power racing plug and have a much thicker ground strap that won't burn off under boost/juice and are gapped around 28 out of the box. they can be a bit cold for some people though.
huh, i would say the tr6's are the most popular nitrous/boost plug out there. is there some new information out there?
just what my motor guy told me to use. he has seen the strap burn off the TR's in several LS-1's and obviously cause some unwanted after effects if you know what i mean. i have seen several R/T Dakota guys do it with their version of the plug when spraying. i am using the A-6's right now in the 408. i don't think they are that new, just not that well known. most of the local performance shops around here carry them. besides, you won't have to fight trying to close the gap to an acceptable size and keep the electrode and anode fairly square.
lucas287
31
Jan 12, 2021 06:18 AM
