tr224 112lsa sound clip on LS1 or LQ9??
Old Aug 9, 2006 | 02:52 PM
TXsilverado's Avatar
Default tr224 112lsa sound clip on LS1 or LQ9??
anyone got a sound clip for me? im thinking about the comp 224 cam on a 112 for the LS1 i might be getting, but i need to be able to keep it under the radar if you know what i mean is it possible to have a 224/224 on a 112 LSA tuned to idle damn near stock?
Old Aug 9, 2006 | 03:03 PM
99/5.3w/hips's Avatar
just get it on a 114 instead...your powerband will just be a little different
Old Aug 9, 2006 | 03:09 PM
silver-mod-o's Avatar
Hunt&Fisherator
yep... the 114 will idle a little smoother... unless you are just dead set on the 112... a little less duration may also be an option. like maybe 222/222 on a 114
Old Aug 9, 2006 | 03:56 PM
ap2002's Avatar
the 224 on a 112lsa is going to be hard to keep it under the radar, this cam sounds damn good, I dont know but maybe they can just set your idle higher than normal to try and cut alot of the choppiness..
Old Aug 9, 2006 | 04:03 PM
wouldnt a 114 lsa be better for your extended cab anyways to help get that movin faster?
Old Aug 9, 2006 | 04:26 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
get it on a 114 and idle it at like 800rpm and you wont notice its there. Why dont oyu want anyone to know its there> Basically you would want an FI since almost none of them lope.
Old Aug 9, 2006 | 04:55 PM
Grumpy5.3's Avatar
my 4.8 has the 224 and it is set to idle at 800 rpms and you can still hear it!!!
i would go with a little less duration, thats just me!!!
Brian
Old Aug 9, 2006 | 05:15 PM
NeverSatisfied02's Avatar
Would putting a cam of that size in a daily driver ruin its reliablility? Id like to put a cam like that in my truck but its a daily driver.
Old Aug 9, 2006 | 06:47 PM
FarmerBeau's Avatar
Sexy Party Mod
Not necessarily. You are gonna want more low end torque of which a tighter lsa provides if im not mistaken.
Remember that cubes eat cams. I heard Colby's TR224 114 (LQ4) and you could tell it was there but you have to listen for it. If you were to idle it up another 100 rpm, you wouldnt hear it. You have to listen right next to the tailpipe to hear my cam but the duration is a tad smaller. The thing about the LQ9 and LS1 is that they are high compression motors and you will hear more of a "pop" in the exhaust note. Im sure with your corsa and bullet, you would have to listen a bit for it if you idle it up.
Old Aug 9, 2006 | 06:54 PM
SlvrSierra4.8's Avatar
Try: www.ls1sounds.com
Take a look under the camshafts tab and there is a couple TR224 112 LS1 clips.
Heres one:
http://www.ls1sounds.com/borlamouth/..._billsride.avi
Seems like a 114 would be your best bet.......
