Tr220
Old Nov 15, 2005 | 09:42 PM
METALMULISHA777's Avatar
Default Tr220
TR 220 114 or 112 ????? any reccomendations
Old Nov 15, 2005 | 09:45 PM
litreddevil's Avatar
Banned
114 if it were me
Old Nov 15, 2005 | 10:03 PM
closet red neck's Avatar
Why???
Old Nov 16, 2005 | 05:01 AM
Sport Side's Avatar
The 112 without a question. Most of the TR cams come with 4* of advance putting your ICL numerically 4* lower than your LSA.
112+4=108
114+4=110
On a 108, hp should peak at near 6000rpm. For proof, check out RGVSierra's dyno graph.
A 114 in my opinion sacrifices too much overlap and will shove power a bit higher in the rpm scale. Of course were not talking about huge losses of low end when comparing equal lobes with small changes in timing events... but the VEs look better on the 112+4
If I were stuck on this cam, I would have TR cut it on a 109-111LSA with no advance. Average power is going to increase from the added overlap and I just like the timing events set up this way. Not every cam needs 4* advance.
Low Compression + mediocre heads + low rpm travel is just asking for overlap.
Old Nov 16, 2005 | 08:15 AM
white1's Avatar
114, unless you like cam surge and dying in parking lots.
Old Nov 16, 2005 | 09:17 AM
TigerFan187's Avatar
OOOHHHH FIGHT FIGHT FIGHT! J/K! Depends on your preferences!
Old Nov 16, 2005 | 09:30 AM
custom 68's Avatar
are the tighter values (lower lsa) harder to tune? I believe they are. I dont tune so will have this done when I make the swap also.
Dave
Old Nov 16, 2005 | 09:36 AM
white1's Avatar
Yea, I have a 112, but I also have a mail order tune, so thats part of the problem. I think you can get it right, but from what I understand, (and have experienced) a 114 is easier to tune.
Old Nov 16, 2005 | 01:28 PM
budhayes3's Avatar
PT's Slowest Truck
The 114 will be easier to tune and more emissions friendly if that's a concern. The 112 should sound a little meaner due to the increased overlap from the tighter lsa.
Old Nov 16, 2005 | 01:46 PM
rgvsierra's Avatar
how bout try both, then report back to us which you like.. lol
