TR220 or 212/218 high lift
Old Jan 12, 2006 | 02:36 AM
ap2002's Avatar
AP talk one of ur buddies into buying it I need cash bad
i'll spread the word out and see who wants it...
Old Jan 12, 2006 | 05:47 AM
tdrumm's Avatar
Originally Posted by mattrem
Tom, I don't mean to be rude. I tried it, don't do it! Stay with the stock rocker. I think you are better off swapping cams. I would go for a Comp with a XER lobe, you will like it.
No problem, some like'em, some don't, I'm not offended
Now what if there was a stock style, made by GM rocker with a 1.8 ratio, Hmmm.....
Old Jan 12, 2006 | 06:58 AM
vettenuts's Avatar
Originally Posted by tdrumm
If all you want is more lift, then why not some 1.8 ratio rockers? Heck of a lot easier than swapping a cam.
I agree. If properly setup with the correct springs, the Crane 1.8 rockers will buy you both lift and valve duration without cahnging cams. And there are several sets for sale on LS1Tech right now. The key factor is to ensure you have enough, but not too much, seat pressure. 130# is a good number to shoot for on the seat.
Old Jan 12, 2006 | 11:28 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
how do you measure the seat pressure?
Hell I just set the valve lash and went
Old Jan 12, 2006 | 01:06 PM
white1's Avatar
I would say go with the TR220. My cam is pretty mutch a high lift version of the 224, and Im running a TB stall. I dont like as mutch as I did the 3000, but it works. Partly because I have a 6l, but I would think it would work with the TR 220 in a 5.3.
Old Jan 12, 2006 | 01:32 PM
TurboGibbs's Avatar
He was refering to the proper spring. The only way you can adjust seat pressure a little bit is by putting shims under the spring. You are limited how much you can do this due to coil bind issues. The proper spring is best.
ap2002 - that's an awful lot of work for such a small change. I wouldn't waste my time unless it was for the TR220. Just plan on doing the stall later if you must. High ratio rocker swap would be easier but twice as much as a cam .
Old Jan 12, 2006 | 08:59 PM
jerome's Avatar
is there somewhere on the thunderracing page that has the tr220 w/ high lift? all i see is the one with .551 lift and 112 or 114 lsa
Old Jan 12, 2006 | 10:59 PM
budhayes3's Avatar
PT's Slowest Truck
...kinda like an LS7 exhaust rocker....
Old Jan 13, 2006 | 12:42 AM
FarmerBeau's Avatar
Sexy Party Mod
The 216/220 will be too much for the tb stall. Curtis ran it with a hughes 2500 and he said it needed a 3K to take full advantage of it. No way around using a small converter and wanting run badass times. My TCI 3K stall just got rebuilt by TCI its brand new now would work great with a tr220 350 and its urs AP.
Then again, Isnt Kevin running a 2500 stall with a cam that is significantly larger than the 216/220. His truck is still lighter though. Just a thought.
Old Jan 13, 2006 | 12:54 AM
ap2002's Avatar
I was thinking the same as you, I would think his is lighter and he has 4.10's.... I am wondering if I could just go with the TR220 and stay with my converter then put some 4.10's?? I wonder how that would work...
