TR220 or 212/218 high lift
Originally Posted by mattrem
Tom, I don't mean to be rude. I tried it, don't do it! Stay with the stock rocker. I think you are better off swapping cams. I would go for a Comp with a XER lobe, you will like it.
Now what if there was a stock style, made by GM rocker with a 1.8 ratio, Hmmm.....
Originally Posted by tdrumm
If all you want is more lift, then why not some 1.8 ratio rockers? Heck of a lot easier than swapping a cam.
I would say go with the TR220. My cam is pretty mutch a high lift version of the 224, and Im running a TB stall. I dont like as mutch as I did the 3000, but it works. Partly because I have a 6l, but I would think it would work with the TR 220 in a 5.3.
how do you measure the seat pressure?
Hell I just set the valve lash and went
ap2002 - that's an awful lot of work for such a small change. I wouldn't waste my time unless it was for the TR220. Just plan on doing the stall later if you must. High ratio rocker swap would be easier but twice as much as a cam
The 216/220 will be too much for the tb stall. Curtis ran it with a hughes 2500 and he said it needed a 3K to take full advantage of it. No way around using a small converter and wanting run badass times. My TCI 3K stall just got rebuilt by TCI its brand new now would work great with a tr220
350 and its urs AP.
350 and its urs AP.
Originally Posted by FarmerBeau
Then again, Isnt Kevin running a 2500 stall with a cam that is significantly larger than the 216/220. His truck is still lighter though. Just a thought.
