TR220 or 212/218 high lift
Old Jan 11, 2006 | 03:27 PM
ap2002's Avatar
Default TR220 or 212/218 high lift
I am seriously thinking about changing my cam out in the next month or so...
I currently have the 212/218 low lift, I like how much it woke my truck up, but I am wanting something with more lift...
I am seriously considering the TR220 with the .581 lift but I dont think my TB converter is big enough.... I really dont want to change my converter, since I really dont want to change it that is why I am considering the 212/218 wtih the high lift..... I have looked into the 216/220 but the lift aint high enough on it...
what would you do:
stay with the 212/218 low lift?
swap to 212/218 high lift?
or swap to the TR220?
or maybe even custom grind a 216/220 with a higher lift??
thanks....
Old Jan 11, 2006 | 03:36 PM
TXsilverado's Avatar
the 216/220 custom grind sounds good...mainly because you can test it before i buy it the 216/220 got sierracrews crewcab movin damn good. it seems like a good cam for heavier trucks like ours.
Nikon02's Avatar
If you do switch and decide to sell you current cam let me know i am interested in a new low lift cam.
Old Jan 11, 2006 | 08:52 PM
tdrumm's Avatar
If all you want is more lift, then why not some 1.8 ratio rockers? Heck of a lot easier than swapping a cam.
Old Jan 11, 2006 | 09:43 PM
mattrem's Avatar
Tom, I don't mean to be rude. I tried it, don't do it! Stay with the stock rocker. I think you are better off swapping cams. I would go for a Comp with a XER lobe, you will like it.
Old Jan 11, 2006 | 10:48 PM
ap2002's Avatar
I have thought about this too, but I have actually read about more people having problems after they change their rockers than people having a great success after swapping rockers..... and knowing me (I am no engine guru) I wont be able to tell a difference if something is wrong with the rockers or not...
Old Jan 11, 2006 | 11:56 PM
dirt track racer 81's Avatar
2nds on the cam if Nikon02 doesn't decide to get it
Old Jan 12, 2006 | 12:07 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The 216/220 will be too much for the tb stall. Curtis ran it with a hughes 2500 and he said it needed a 3K to take full advantage of it. No way around using a small converter and wanting run badass times. My TCI 3K stall just got rebuilt by TCI its brand new now would work great with a tr220 350 and its urs AP.
Old Jan 12, 2006 | 01:33 AM
ap2002's Avatar
Cody, dont tempt. me
Im on a low budget... still got to install the posi and get a dyno tune after the secret mod...
Old Jan 12, 2006 | 01:37 AM
1slow01Z71's Avatar
AP talk one of ur buddies into buying it I need cash bad
