tr 224 in a 6.0
Old Jun 2, 2006 | 03:49 PM
which TR224 is it? A 112LSA or 114LSA. I think a TR224 on 114LSA with 4* advance will have great low end TQ and will tow good with a Trail Blazer stall. The higher stall you go while towing, the hotter the tranny will get with the TQ convertor unlocked.
If you dont already have the cam you should look into the "old man" cam. Its a fairly small cam with high lift and works well for towing.
Old Jun 2, 2006 | 04:23 PM
Its the lunati 224/224,563/563. on 114,ande the truck is a 2500 4x4 with a 4l80e.Man this truck is slow,my rcsb z71 would eat its lunch,but i needed a truck to tow with. so here i am
Old Jun 2, 2006 | 04:40 PM
black4.8's Avatar
on the small side for a 6.0, but still a little large for towing. just my opinion tho. most guys like the tr224 over the lunati also.
Old Jun 2, 2006 | 06:09 PM
is the thunder racing 224 not ground by lunati?
Old Jun 3, 2006 | 10:02 AM
Are you also swaping the springs? I know it may be a dumb question.
That cam is a little different then the TR224, but since you already have it use it. Just install it 4* advanced to lower the power range down. It should still have good low end like that for towing and possibly increase you milage a little. I didnt tow with my Silvy but with the LPE GT1 cam I got up to 20mpg with 4.10's.
Me personaly I tow @6-7K quite often with my Yukon and will be swapping out to the "old man" cam because they are renound for low end grunt. They have had dyno's with as much as 40hp over stock through the mid range. Thats huge. I want as much more TQ as I can get between 1700-2500rpms for towing, but dont want to go FI because it eats gas.
Old Jun 3, 2006 | 10:24 AM
Yeah i went with a lg motorsports g5x3 in the camaro so i pulled the 918s out and went with prc duals.Im going to put longtubes on the truck next week we will see how much that helps it.Just wish i had a stall for a 4l80e laying around.
Old Jul 20, 2006 | 09:21 PM
Derek @ EDO's Avatar
FormerVendor
I think Cam Motion Grinds Thunder and Futrals cams.
Old Jul 20, 2006 | 10:12 PM
budhayes3's Avatar
PT's Slowest Truck
When I was cam shopping a while back, I had some correspondence with Thunder and they recommended against the TR224 for a heavy truck...and my truck's a rcsb 1500, although it is a 4x4. I did mention that I don't tow a thing, and they recommended their 220 at the most, with around a 3k stall.
Oh yea, and I thought that Thunder uses Comp lobes...
Old Jul 21, 2006 | 03:12 PM
Sport Side's Avatar
Thunder - Comp lobes
Futral - Cam motion
... doesn't really matter tho
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
