Toughest Electric Cut-Outs?
Old Apr 21, 2007 | 03:58 PM
CHarris's Avatar
Default Toughest Electric Cut-Outs?
I need some recommendations on this one....
I'm seeing a need for cut outs on the new KB 2.8 set up. I blew my passenger side exhaust open yesterday at a clamped section. It was a slip fit before yesterday.... now both sections are the same size This was AFTER the cats.
So... I clearly need more exhaust flow to uncork this system. My thoughts are for a pair of 2.5 inch cut outs to install in front of my cats so I can open them when I want but still be quiet on the street. Who makes electric cut outs that won't melt or bend?
Old Apr 21, 2007 | 04:22 PM
I've never had much luck with electric cut outs they always seem to leak after a few months,QTP makes them.
Old Apr 21, 2007 | 05:36 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
QTP + aluminum gaskets work pretty well, but if you're FI make sure they give you the steel geared version.
I've got a used one I'll be selling with the steel gears, but only have one.
Old Apr 21, 2007 | 06:03 PM
Ferocity02's Avatar
Go with DMH. My QTP's fell apart, literally, in only two weeks, then charged me to fix their pieces of ****.
Old Apr 21, 2007 | 09:56 PM
91_bowtie's Avatar
same here, but mine lasted almost 3 months. It leaked from day one. I could stop the leak, if I held the switch closed. When I told them about the issue, they said it was an improper installation. If the leak went away when I held the switch closed, how is that a bad install? A couple months later, the plate blew off when I was driving down the highway. I have several problems with there design. You couldn't pay me to put another one of those pieces of **** on my ride.
I'd recommend getting one from Keith McCord. It's cheaper than the others, but a better built unit. Instead of having barely enough room to get a nut on the bolts, this design has slots, so there is room for adjustment and an overall better fit.
Old Apr 22, 2007 | 12:15 AM
CHarris's Avatar
Thanks for the feedback so far! Does Keith have a website?
Any more comments anyone?
Old Apr 22, 2007 | 12:32 AM
91_bowtie's Avatar
yes, but he's not a sponsor.
pm sent
Old Apr 22, 2007 | 12:37 AM
99Silver6.0's Avatar
DMH or the Dougs guillotine style will be the best bet.
Old Apr 22, 2007 | 03:15 AM
dropkick13's Avatar
so basically on my stock exhaust piping i would have a 3" cutout welded either right before the cat or right after and then McCords power plate welds to the cut out? is this cut out fine for this:
http://store.summitracing.com/partde...5&autoview=sku
What would a shop probably charge for these welds?
Old Apr 22, 2007 | 07:18 AM
ss64impala's Avatar
i got mine from badlanze, works great.
