Toughest Electric Cut-Outs?
I need some recommendations on this one....
I'm seeing a need for cut outs on the new KB 2.8 set up. I blew my passenger side exhaust open yesterday at a clamped section. It was a slip fit before yesterday.... now both sections are the same size :bomb: This was AFTER the cats. So... I clearly need more exhaust flow to uncork this system. My thoughts are for a pair of 2.5 inch cut outs to install in front of my cats so I can open them when I want but still be quiet on the street. Who makes electric cut outs that won't melt or bend? |
I've never had much luck with electric cut outs they always seem to leak after a few months,QTP makes them.
QTP + aluminum gaskets work pretty well, but if you're FI make sure they give you the steel geared version.
I've got a used one I'll be selling with the steel gears, but only have one. |
Go with DMH. My QTP's fell apart, literally, in only two weeks, then charged me to fix their pieces of shit.
http://img.photobucket.com/albums/v7...r/DSCN3248.jpg I'd recommend getting one from Keith McCord. It's cheaper than the others, but a better built unit. Instead of having barely enough room to get a nut on the bolts, this design has slots, so there is room for adjustment and an overall better fit. |
Thanks for the feedback so far! Does Keith have a website?
Any more comments anyone? |
yes, but he's not a sponsor. :secret:
pm sent |
DMH or the Dougs guillotine style will be the best bet.
so basically on my stock exhaust piping i would have a 3" cutout welded either right before the cat or right after and then McCords power plate welds to the cut out? is this cut out fine for this:
http://store.summitracing.com/partde...5&autoview=sku ??? What would a shop probably charge for these welds? |
i got mine from badlanze, works great.
