torque specs please
Old Mar 19, 2009 | 08:01 PM
POPO1984's Avatar
Default torque specs please
Can anybody give me the torque specs for the heads and intake on an 08 5.3 with dod
Old Mar 24, 2009 | 09:49 PM
woodardcoin's Avatar
Intake Manifold Bolts - First Pass in Sequence 5 N.m (44 lb in)
Intake Manifold Bolts - Final Pass in Sequence 10 N.m (89 lb in)
J 41798 M8 Bolt 25 N.m (18 lb ft)
J 41798 M10 Bolts 50 N.m (37 lb ft)
Throttle Body Bolts 10 N.m (89 lb in)
Throttle Body Nuts 10 N.m (89 lb in)
Throttle Body Studs 6 N.m (53 lb in)
Cylinder Head Bolt
Cylinder Head M11 Bolts - First Pass in Sequence 30 N.m (22 lb ft)
Cylinder Head M11 Bolts - Second Pass in Sequence 90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence 70 degrees
Exhaust Manifold Bolts - First Pass 15 N.m (11 lb ft)
Exhaust Manifold Bolts - Final Pass 20 N.m (15 lb ft)
Old Mar 24, 2009 | 10:09 PM
Lama1's Avatar
Small head bolts (8mm thread with 10mm hex) = 22 ft. lbs.
Some quick tips:
1)Drain the coolant just from the heads, not the whole radiator, by removing the water temperature sensor on the driver side head. Do this right before you are ready to remove the head crossover steam pipe. If you are changing the cam, then of course, drain the entire system,and remove radiator.
2) Soak the exhaust flanges (3 nuts) with PB blaster and let them soak for a long time. Use a 15mm box end wrench on the passenger side 2 nuts, a socket and ratchet on the 1 nut on pass. side that is easy to get to, and on all the drivers side.
3) Use an air ratchet, makes the job quick.
4) Just unplug the brake booster line at the diaphram, not on the manifold.
5) Remove 4 long 15mm hex and 1 short 15mm hex bolts from the alternator/power steering pump bracket, and carefully lower it and let it rest against the radiator fans. be careful not to pull on the cam sensor wires below this unit.
6) Remove the exhaust maniold to head bolts SLOWLY, and soak with PB Blaster. They use loctite at the factory, and these bolts can strip your heads or break.
7) Clean the old head gasket residuals from the heads with a new single edge razor and a small wire brush. Use some brakeclean to final wipe the surfaces. The MLS gaskets leave minimal gasket residual on the surfaces. Nice.
8) Mark the injector harness grey connectors (Sharpie) with the corresponding cylinder numbers 1-8. The rest of the engine harness is idiot-proof.
madmann26
Apr 29, 2020 09:17 AM
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
jscherbs
Sep 30, 2015 07:54 AM
