Torque Specs
Old Mar 12, 2005 | 10:42 AM
Default Torque Specs
Hey what's up guys!
Time to refresh the motor. Do you guys know of a website or place I can get information on the torque specs for the head bolts and intake bolts.
I only torqued the head bolts to 36 lbs and they have backed out. Does this sound about right as far as ft lbs?
Any info would be greatly appreciated so I can stop driving a pinging truck,
thanks.
Old Mar 12, 2005 | 12:12 PM
KLUG'S SS's Avatar
FormerVendor
There are four steps to torqueing the head bolts.
Step one- All 11mm bolts 22ft lbs
Step two- All 11mm bolts turn an additional 90 degrees
Step three- 11mm bolts (1 through 8) turn an additional 90 degrees
11mm bolts (9 and 10) turn an additional 50 degrees
Step four- All 8mm bolts 22ft lbs
did you do them in the right sequence? This info is right out of a tech manual. Also did you use new bolts because the head bolts are not reusable.
Old Mar 12, 2005 | 12:16 PM
silent1's Avatar
This website has most of the specs you'll ever need.
www.ls1howto.com.com
Old Mar 12, 2005 | 01:11 PM
Thanks for the link, it will be very helpful.
KLUG'S SS - I reused the old bolt cause none of them were broken , My mechanic says to just put 5 extra lbs on each bolt. Thanks for letting me know about the sequence though!
Another question though! The spec sheet says 44lbs 1st pass and 89 lbs 2nd pass. Isn't that a bit too much for plastic intake manifold?
Old Mar 12, 2005 | 01:44 PM
silent1's Avatar
DO NOT RE-USE HEAD BOLTS!
As for the intake manifold, that's inch/pounds not foot pounds.
Old Mar 12, 2005 | 02:08 PM
Why not?
So just divide the 44 and 89 by 12
Old Mar 12, 2005 | 03:45 PM
silent1's Avatar
Originally Posted by 2000_Silverado_SS
Why not?
Our head bolts are "torque to yield" bolts that have a certain amount of stretch to them. That "stretch" is reached when they are torqued down the first time they're used. The head bolts do not return to their original state after this. In re-using them you are risking uneven torque pressures across the head or you may even break off a head bolt in the block. Definitely not worth trying to save a few bucks. Now, head studs are re-useble and make the job much easier and cleaner.
Old Mar 12, 2005 | 04:18 PM
KLUG'S SS's Avatar
FormerVendor
You don't divide the 44 and 89 by 12, it is just 44in lbs and then 89in lbs. Also silent1 put it perfect perspective for the head bolts if you continue to reuse them they are going to keep backing out on ya.
Old Mar 13, 2005 | 06:42 AM
ok, I'll get new head bolts when I get my new heads in then.
Old Mar 13, 2005 | 09:17 AM
litreddevil's Avatar
Banned
We have reused head bolts a few times and never had a problem yet.How often have you guys hear of someone breaking a head bolt?The only reason they backed out because he did not tq them enough the first time.
