Torque management removal can blow tranny??
Old May 15, 2003 | 12:44 AM
INDIGO 5.3's Avatar
Default Torque management removal can blow tranny??
I have done some research on TM in this forum as I am going to have my PCM reprogrammed and also going to have all the TM removed. I read somewhere in this forum that if you remove the TM it will ruin the tranny, is this true?? Any help would greatly be appreciated.
Old May 15, 2003 | 04:10 AM
MGMC's Avatar
12 Second Club
Default Re: Torque management removal can blow tranny??
The purpose of TM is to pro-long the life of the tranny..In other words, your tranny wont last as long as a tranny w/ TM (If it is stock). Judging by the tranny mods in your sig, you shouldnt have a problem.
Old May 15, 2003 | 09:30 AM
BigKID's Avatar
With the addition of the servos you should be ok. Also while you are having someone program your truck, have them boost the line pressures a little and reduce your shift timing at higher rpms/throttle postitions.
99bluefirebird
Sep 17, 2015 08:05 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
lxcoupe
Aug 31, 2015 05:49 PM
