Torque management removal can blow tranny??
I have done some research on TM in this forum as I am going to have my PCM reprogrammed and also going to have all the TM removed. I read somewhere in this forum that if you remove the TM it will ruin the tranny, is this true?? Any help would greatly be appreciated.
Re: Torque management removal can blow tranny??
The purpose of TM is to pro-long the life of the tranny..In other words, your tranny wont last as long as a tranny w/ TM (If it is stock). Judging by the tranny mods in your sig, you shouldnt have a problem.
With the addition of the servos you should be ok. Also while you are having someone program your truck, have them boost the line pressures a little and reduce your shift timing at higher rpms/throttle postitions.
