torque management help
Old Nov 26, 2003 | 10:31 PM
  #21
parish8's Avatar
single digit dreamer
i emailed carputing to see if they have any ideas, i am sure there will be a way to fix it. i am not in that big of a hurry. i just hope it has a limit to how far it can close, i am spraying right at it and plan on uping my shot.
Old Nov 27, 2003 | 06:19 AM
  #22
hi parish,
I just got Edit, and haven't tried it on my truck yet. But I have been reading the manual (several times). Anyway, I noticed that there are a few ETC specific controls that might be affecting you. 1) There is an ETC rev limiter by gear in the 'Idle + Limiters' tab. In the stock 6.0 LQ4 file I downloaded to look at, this value is set at 5600rpm, which matches your data. 2) Also, on the speed limiter tab there's a max mph/sec value, but this doesn't match your data. 3) Finally, on the ignition tab there's a tip-in torque graph that I think is enabled based on the same delta airflow as the burst knock. I know the burst knock pulls timing, but could the tip-in trq affect TPS too???
Hope this helps, and good luck with your new engine.
Old Nov 27, 2003 | 08:38 AM
  #23
parish8's Avatar
Originally Posted by deezel
hi parish,
my tip in tq is all at 640 so i doubt that is a problem, i kicked the electronic speed limiter up to 160mph, it was at 96?, and i pushed it up to about 115 and it was still speeding up so that seemed to work.
that other table, "ETC rev limiter", looks interesting, i dont have ETC so i didn't really look at it but it is set at 5600, i will bump it up and try it later today.
Old Nov 27, 2003 | 08:50 AM
  #24
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Yes, you DO have Electronic Throttle Control! (ETC)
Old Nov 27, 2003 | 08:52 AM
  #25
Flyer's Avatar
Are you hitting a rev limiter parish? I notice on mine it doesn't bounce like your traditional rev limiter, it runs up to it and pulls throttle.
I've got to say, when I first noticed the try was electronic throttle, I was like man that thing is gonna have lag in it from the time I step on it to the time it opens WOT, but apparently that motor to control it is fast as hell. It will slam shut in about a half second judging from what ATAP says.
Later on I will try something to make sure I'm getting the right counter. I noticed EFILive has several things for the TPS.
Old Nov 27, 2003 | 09:03 AM
  #26
parish8's Avatar
thinking Electron Traction Control. it would be sweet if this works, i like the clean look of the drive by wire.
Old Nov 27, 2003 | 09:08 AM
  #27
Speartech's Avatar
I think you just found your problem!
Old Nov 27, 2003 | 10:39 AM
  #28
parish8's Avatar
HELL YEA!!! check this out.
now thats what i am talking about, thanks for your help guys.
now it is time to work on that shift, look at the rpms at the 1-2shift, once it starts to shift it takes 1.5sec to finish, it feels just like it looks, just kind of slips into 2nd over a loooooong period of time. i will start a new thread for that one.
oh yea, somtimes i see a - timing number right at the shift but it is just one cell sometimes nothing to worry about. and it feels sooo good now, i even got a small 2nd gear scratch
Old Nov 28, 2003 | 06:29 PM
  #29
one03sierra's Avatar
Formerly one92rs
i believe i mentioned i was having a problem with my tranny shifting and the engine falling on its face. today i located my paperweight predator and gave it a look see.i am at 28.4 spark advance till i shift then it drops to 12.9 to 18.2 then picks up to 28.6. believe that lyndon left a couple a tables to be tweaked some.going to have farmtruc take a look at it. any advice on the tables to look at would be greatly appreciated. thanks
Old Nov 28, 2003 | 10:03 PM
  #30
Glad that worked for you!
