torque management help
Old Nov 24, 2003 | 10:43 PM
parish8's Avatar
single digit dreamer
Default torque management help
GRRRRRRR, this isn't working well. i have serious TM, i went thru the steps and still have it bad, expecialy the closing throttle blade at the shift.
here is what i did.
1. Transmission -> A4 Shift Firmness -> Torque Reduction...Fill the whole table with zero's
2. Trans Calibration -> A4 Shift Firmness -> Upshift Torque Reduction...Fill the whole table with zero's
3. Engine -> Ignition -> Max Torque...Set it to 639,
4. Engine -> Ignition -> Torque Reduction...Fill the whole table with zero's
and it didn't seem to make any diference, this things falls on it's face HARD at the shift. here is a section of atap, remember i had it floored the whole time.
Old Nov 24, 2003 | 10:46 PM
ThunderZ28's Avatar
12 Second Club
i dont know for sure parish but i was told that the abuse mode might pull timing from the motor. i was told to zero that table out too but have yet to get around to trying it.
i did the same thing you have shown and mine does not fall. it shifts real nice.shift and go.
hope this helps you.
Later
Daniel
Old Nov 25, 2003 | 03:08 AM
Flyer's Avatar
Man .. that blows .. I'm gonna be pissed itf I can't get around that. Especially when the throttle starts to close at 95.
I'll be tempted to put a mechanical TB on there ...
Old Nov 25, 2003 | 06:00 AM
one03sierra's Avatar
Formerly one92rs
Unhappy
i am having the same problem with my built tranny. when it shifts it falls on its face. hopefully farmtruc can take care of it this weekend.
Old Nov 25, 2003 | 06:13 AM
L-EATER's Avatar
11 Second Truck Club
When you figure it out please let me know-I have been living with the same prob since the Fall of '01! Superchips was supposed to take it out when I went to their facility and had it tuned back in Feb of '02 but they didn't. I have asked on here before what it would take PCM wise to convert to a cable but never got a definite answer.
Old Nov 25, 2003 | 08:33 AM
11 Second Club
Have you tried to change the shift time? Maybe put a vacum actuated shift solinoid in?
Old Nov 25, 2003 | 11:28 AM
XLR8NSS's Avatar
Adkoonerstrator
Engine--->Spark Retard Limit--->0 it out or if your brave put the max timing you see before a shift in .
That table is the ONLY thing that stopped my computer from pulling timing on the shift. I think it blew my trans up adding all that timing on the shift though.
Try it and let us know.
Old Nov 25, 2003 | 11:32 AM
XLR8NSS's Avatar
Adkoonerstrator
Hmmmm....just looked again and timing doesn't seem to be your problem until the computer starts shutting the TB blade. I think you need to convert back to a old physically linked TB. Maybe Speartech could shed some light on the TB closing problem and if there's a way around it through programming??
Old Nov 25, 2003 | 11:49 AM
Flyer's Avatar
It sounds like this is going to be a problem with the new trucks. I was telling a friend about my truck closing the throttle some at 95 and leveling off at 100 and another friend that works at GM was there. He said it was a 'feature'.
I wish I had the 1.3 to look at so maybe I could help you out.
Old Nov 25, 2003 | 11:58 AM
BigTex's Avatar
EEEEKKKKK. I really need to look at my throttle position. My 1-2 shift is sluggish. I was thinking transmsion, but it may be TM causing it. I have got timing through it all, but haven't looked at my TB position.
Manual throttle body looks very good to me right now.
