Too many damned choices!
Old Mar 31, 2004 | 09:48 AM
Scream's Avatar
MOOBIES Moderator
Yes, and about 80-100 pounds.
Old Mar 31, 2004 | 09:57 AM
so really a good package would be to put the 6.0 aluminum heads on the ls1 with a radix and a nice cam. What does anyone think about rwhp levels. I looked on ebay and you can pick up the ls1 for around 2500-4000. Alot of these are also coming with a transmission. Never hurt to have a extra one.
Old Mar 31, 2004 | 01:08 PM
Sport Side's Avatar
scream,
how much did it end up costing you when all said and done?
Old Mar 31, 2004 | 01:17 PM
Scream's Avatar
MOOBIES Moderator
Originally Posted by SportSide 5.3
scream,
I might not be a good example...I got the longblock for $500, and then did the following:
  • ARP main studs, head bolts, rod bolts
  • new cam bearings
  • new Clevite 77 "H" series bearings
  • new GM rings
  • 31# 8.1L injectors
  • TR 224 cam
  • 918 springs and TR pushrods from old setup
I haven't added everything up yet, but if I'm not mistaken I came in at just under $2500. My goal was to come in under 1/2 the price of the beloved, almighty Radix, and I think that I succeeded.
Old Mar 31, 2004 | 01:26 PM
Sport Side's Avatar
yea gj. and your probably makin more power than you would of gotten with one on your 4.8
Old Mar 31, 2004 | 03:08 PM
blacksheep's Avatar
Stock short block can't handle much juice? 200 did just fine on my stock short block.
Old Mar 31, 2004 | 03:36 PM
  • new cam bearings
  • new GM rings
  • TR 224 cam
Were the 8.1 injectors direct replacements?
Old Mar 31, 2004 | 10:10 PM
954RR's Avatar
Hopefully because that is what I am going to be running in my LS1 here in a week or so.
Scream does that 224 lope much? Mine is on a 112lsa and I want it to kinda be a secret to unsespecting cars without turning the idle up too much
I am haveing a ton of stuff done to my heads too P&P, big valves, milled down .30 and some other things. I think the LS1 swap will definatly be worth it.
Old Apr 1, 2004 | 06:51 AM
Scream's Avatar
MOOBIES Moderator
The 8.1L injectors are a direct swap. The TR224 cam has a little chop to it, but can be hidden well with a quiet exhaust. Although, I haven't had mine tuned yet.
Old Apr 1, 2004 | 08:38 AM
F8L Z71's Avatar
Now I am thinking it might not be worth all the effort since I am now keeping my T/A.
I talked with one of the guys at STS (rear mount turbo guys) and if I can get the right deal I may just go with one of those and the SMC Alk kit. This way I don't have to do any swaps and makes it nice and easy for smog next year. Plus I like the idea of a turbo
