TM does work
Old Oct 17, 2004 | 04:14 PM
Black02Z71's Avatar
Default TM does work
I found out today that my stock 4L60E can't take a WOT shift without TM. It is pretty cold out today (9c) so I went out and did a couple of runs, after changing the shift points up to 6100, and lowering the TM. I was seeing a timing drop of 14 degrees at the shifts before, after lowering the TM I was only seeing a drop of 3-5 degrees.
1-2 shift
bucking 2-3 shift
Old Oct 17, 2004 | 04:22 PM
Black02Z71's Avatar
1-2 shift I could feel it slip a little, on the 2-3 shift it started surging like crazy like it was hiting the rev limiter, and I had to let off the throttle.
So I need to start thinking about a better trans. Built 4L60E or 4L80E?
I want to make her last the winter, so I put the TM back in, plus a little.
Old Oct 17, 2004 | 04:53 PM
99Silver6.0's Avatar
Id say you could do a built 65E. Unless you want an 80.
Old Oct 17, 2004 | 05:20 PM
Black02Z71's Avatar
I was thinking of finding a cheap 4l60e core and built it myself, an 80 would be more then I need, plus extra work, cost, and would need a new torque converter. What I really want is a 6L80E , but I would need a time machine to get one of them.
Old Oct 17, 2004 | 05:48 PM
The cost of the 80 is what made me decide on a built 60. Till I ran across a good deal on a 65E. With what I want to accomplish, I wouldnt even test the strength of the 80E.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
