timing chain Q's
Old Feb 13, 2008 | 04:01 PM
blown 04's Avatar
Default timing chain Q's
Hey guys, I was planing to do a cam swap this weekend, got every thing i thought i would need but forgot about t-chain. Idid a search about this and
seems like most will say change it out for insurance. My truck has 60,000 on the clock, should i wait and get one? Do you have to get the oil pump alinged on the crank or do you just bolt it on? From what i have read the oil pump is what gives the most trouble, thats why if i can get away with not touching it the better. Give me your expert opinons
Old Feb 13, 2008 | 06:02 PM
Eye-P's Avatar
At 60k you should replace the chain. You could get the LS2 chain locally and spend less than $50.
Old Feb 13, 2008 | 06:23 PM
cmitchell17's Avatar
I thought timing chains would run for the life of the engine(200k+).
I want to do a cam swap too, but I would rather just be able to do the cam and not have to change springs and the timing chain with it.
Old Feb 13, 2008 | 06:27 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Uh, you don't have to do the chain but while you're in there.....
Swapping springs is dependant on what cam you decide to run
Old Feb 13, 2008 | 06:56 PM
kbracing96's Avatar
Personally, at only 60K i wouldn't worry about the chain. They will run a LONG time, and it's a bit of a hassle to change since you have to pull the oil pump and fight with getting it off and on with out taking the pan and pickup tube off.
Old Feb 13, 2008 | 07:04 PM
usarmyman's Avatar
I thought you had to pull the chain to remove the cam anyway? Or is that just on Gen 1 and 2 motors, or am I just crazy?
Old Feb 13, 2008 | 07:20 PM
kbracing96's Avatar
You take the upper cam gear off, but the chain doesn't have to come off the lower gear.
Old Feb 13, 2008 | 09:13 PM
Ive been looking but I can't find it, but how much lift will the stock 5.3 springs take.
Is it completley worthless to try to run a stock like lift cam? Do you really need the lift? It looks like the 4.8/5.3 heads don't really flow much in the .500 and .600 lift.
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
