timing chain play
Old May 2, 2004 | 07:44 PM
hdhorsepower's Avatar
Default timing chain play
hey guys just putting in a new cam in my truck and was wondering how much play you can have in the chain and be alright.my truck only has11000 miles on it and didnt want to mess with the oil pump if i didnt need to but the stock chain seems sloppy.by the way the cams specs are 214 220 .579 .580 on a 114+4.thanks alot
Old May 2, 2004 | 08:03 PM
67SS509's Avatar
10 Second Truck Club
If you put a new chain it will be loose again in 100 miles. Besides, the new chain is not going to seem much tighter. Just the nature of the beast. At 11k your old one should be fine.
Which springs are you going to use?
Old May 2, 2004 | 08:08 PM
sleepersilverado's Avatar
they are all sloppy and gm i believe deals with that by grinding advance in the cam
Old May 2, 2004 | 08:32 PM
BigTex's Avatar
Who makes a cam grind with those lobes specs?
Old May 2, 2004 | 09:25 PM
its a custom grind from comp cams. thanks guys i was just worried with the slop ,but if they are all like that i will just put it back on.
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
