Which timing chain for 6.0?
Old Jan 19, 2004 | 06:55 PM
Default Which timing chain for 6.0?
im gatherin parts for the 6.0 im buildin....all i need now is head bolts, gaskets, injectors, and a timing chain....i was just wanderin which one u guys think i should run..i kinda want to get a single instead of a double roller b/c i heard u have to modify the crank pulley if u get a double...so whats every1 else runnin?
Old Jan 19, 2004 | 07:02 PM
sleepersilverado's Avatar
i have a double. the only pullies you have to modifie are the asp. i did not modify my stock pully. i believe it is cloys has a prety good single. i have the slp double. i remember there being a thread a while back about the breakage of the chanes from stock to double and if i remember correctly they all broke about the same. you should be fine with whatever i know some real powerfull fbods running stock chains.
Old Jan 19, 2004 | 07:33 PM
is it important to get an adjustable one or not?
Old Jan 19, 2004 | 09:10 PM
ttttt
Old Jan 19, 2004 | 09:43 PM
Up to you. You may want to advance or retard your cam later. I think you can do with just an allen wrench on some.
Old Jan 19, 2004 | 09:45 PM
hey guys there is some1 on this site trying to sell me a single comp adjustable chain...is this a good one to go with? thanks!
Old Jan 19, 2004 | 11:51 PM
i dont know about the comp. the adjustible part is not all that important. but makes it nice if you want to adjust it but then you have to get the degree wheel out and all that. i would just order the cam i want with the retard or advance ground in.
Old Jan 20, 2004 | 12:22 AM
I bought a JWIS chain for my future 5.3 build-up. I might change the gears on it too, not decided yet.
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
