time for 6.0 swap. few questions
Old Jan 30, 2009 | 09:22 AM
ineedatruck's Avatar
my 4.8 popped yesterday so the time has come.
i wont have to do any mods at all to a lq4/lq9 to bolt straight in plug my 4.8 harness up? just have 4.8 ecu sent to be tuned? right?
Old Jan 30, 2009 | 11:09 AM
budhayes3's Avatar
PT's Slowest Truck
That is correct, just make sure that you use the 4.8 flywheel if you're using the trans that the truck came with.
Old Jan 30, 2009 | 02:50 PM
gmc6.0's Avatar
Hey how is that build coming along....
Old Feb 1, 2009 | 08:45 PM
harp's Avatar
I have a 2004 lq4 6.0 complete but no trans i dont need since i bought a nnbs cc
Old Feb 1, 2009 | 09:19 PM
nunleysz's Avatar
you need my ly6.throw a cam in it and you will have a beast for cheap!
Old Feb 2, 2009 | 10:11 AM
i cant find many 6.0 in town so i found buncha 5.3s is it the same swap over as the 6.0?
do i needa switch anything on the 5.3 from the 4.8
Old Feb 2, 2009 | 11:26 AM
budhayes3's Avatar
PT's Slowest Truck
The PCM will need adjustments, but everything else will bolt up the same.
Old Feb 2, 2009 | 12:28 PM
Mangled03gmc's Avatar
Baltimore Whore
Honestly just wait till you do come across a 6.0
Everything swaps over
Depending on hp is where i would decide what trans to go with. If you plan to keep it mild, a built 65 0r 60 should do you fine. Along with a decent converter-3000. and a decent cam in the 218-220 range.. You should be plenty happy
Old Feb 2, 2009 | 01:38 PM
harp's Avatar
man i cant give this 6 0 away it was the hottest thing when i was looking to do the swap now all i get are window shoppers
Old Feb 2, 2009 | 03:33 PM
the 6.0s i have found. dont have alternator. starter so on and no wiring harness.
will all that 4.8 parts fit no problems? what baout manifolds? im gonna buy a motor tommorow
