time for 6.0 swap. few questions
That is correct, just make sure that you use the 4.8 flywheel if you're using the trans that the truck came with.
Everything swaps over
Depending on hp is where i would decide what trans to go with. If you plan to keep it mild, a built 65 0r 60 should do you fine. Along with a decent converter-3000. and a decent cam in the 218-220 range.. You should be plenty happy
