time for 6.0 swap. few questions
Old Jan 18, 2009 | 03:55 PM
ineedatruck's Avatar
Default time for 6.0 swap. few questions
finally gonna do the swap i sucked water through my 4.8 and its knocking really bad.
2007 classic body crew cab 2wd 4.8l with an auto.
which motor tranny combo should i look for?
any known places with good deals?
and whats gonna be a nice daily drive cam? dont want a huge stall i drive 100 miles stop and go each day
Old Jan 18, 2009 | 04:39 PM
00Silv4.8's Avatar
LQ4/9-4L80E.
I would go with something around 220s 218s, you have alot of truck to be moving
Old Jan 18, 2009 | 04:43 PM
dlt76028's Avatar
2001+ 6.0 with aluminum heads is what you want. i wouldnt get a 4l80 in that crew cab i would just beef up your 4l60 especially since its pretty new. look into the tsp 220 with a 3000 stall.
Old Jan 18, 2009 | 04:49 PM
SynergyV8's Avatar
Shouldn't an '07 still be under warranty?
If you're commuting ~100 miles a day, either a 5.3L or 5.7L would return better gas mileage than both the 4.8L and 6.0L.
Old Jan 18, 2009 | 06:12 PM
sonoma43's Avatar
Originally Posted by SynergyV8
Shouldn't an '07 still be under warranty.
No doubt, go use that warranty, have them put the new motor or good parts in whichever then pull it and sell it. Make a few dollars to put towards the new build!
Old Jan 18, 2009 | 07:30 PM
i wish i could warranty but it went out a year ago at 36k miles i now have 70k.
so lq4/lq9 will all bolt right in? can i get a bare long block and switch all my accessories over? and a local shop has a heck of a deal on a 4l60e build il run with.
and im gonna be installing 4.56-4.88s truck is a pre runner style on 35s, maybe going 37s
Old Jan 18, 2009 | 08:49 PM
dlt76028's Avatar
yep a long block is what you need.
Old Jan 18, 2009 | 09:02 PM
SynergyV8's Avatar
I was not aware of the 35-37" daily driven crew cab idea.
Re-using your 4.8L block and turning it into a 6.3L would yield the best gains for a lifted truck.
Old Jan 18, 2009 | 09:05 PM
silveradol33's Avatar
Do an LQ9 with a mild tr224 cam and maybe some head work, long tubes and a nice 3k-3200 stall and call it a day.
Old Jan 18, 2009 | 10:06 PM
budhayes3's Avatar
PT's Slowest Truck
Warranty doesn't cover an engine that ingested water, it's not the General's fault that floods and deep puddles happen
For a daily driven CC that's goes 100 miles a day and doesn't want a large verter, I'd go with the afore mentioned 01+ LQ4/9, a mild cam like a 216/220 or 218/22x on a 114, a Yank TT2600, and an FLT Level 5 4L65E
