ticking after heads and cam swap on LS1.
Old May 20, 2013 | 11:24 PM
2doorfury's Avatar
Default ticking after heads and cam swap on LS1.
Just did a head and can swap on my neighbors 2001 camaro ss. Used new LS7 lifters and Texas speed 7.4 pushrods. Heads are unmilled. Has a tsunami can. Has a loud tick on passenger side and it only sounds like a single tick. Could it be a lifter not pressurized with oil yet? Any thoughts or ideas?
Old May 20, 2013 | 11:26 PM
2doorfury's Avatar
Also used original lifter trays if that means anything..
Old May 21, 2013 | 12:09 AM
Mangled03gmc's Avatar
Baltimore Whore
People going to say the push rods are prob to long, you have to much PL. Go back over the valves again, possibly check the PL on the side you think has the tick. Or it could be just a lifter that isn't pumped yet.
Old May 21, 2013 | 12:50 AM
fastjweb's Avatar
I might be wrong, but dont you need to run the ls2 style lifter tray with the ls7 lifters?
Old May 21, 2013 | 12:56 AM
2doorfury's Avatar
Being that it sounds like one lifter/rocker..I might agree on lifter not primed yet. I'll go over the valves again And see what I find.hopefully thats all it might be.
Old May 21, 2013 | 01:12 AM
Baltimore Whore
I believe that could be a myth
Old May 21, 2013 | 01:31 AM
2doorfury's Avatar
I used regular lifter trays and LS7 lifters when I built my engine..can't say I heard that.
Old May 21, 2013 | 01:07 PM
gagliano7's Avatar
Make sure you don't have an exhaust leak. Tick will sound the same.
Old May 21, 2013 | 01:44 PM
2doorfury's Avatar
I'll check and make sure there isnt a leak at the header flanges. Never really thought of that. Thanks
2doorfury's Avatar
Kinda sounds like 2 marbles hitting each other..
