Ticking after a cold start????
Old Feb 17, 2010 | 02:48 PM
chiliz666's Avatar
Default Ticking after a cold start????
For a few days this has been going on. After the truck has sat for a while, when I start it up and as its idles and I give it a little gas, a ticking noise I can hear. The ticking sounds like its something plastic, its on the passenger side of the eng. The ticking is relative to the tach, the truck runs fine and the ticking stops after its normal temp. Any ideas?
Old Feb 17, 2010 | 03:03 PM
MDI2500HD's Avatar
Sounds like you have a broken exhaust manifold bolt. The ticking is the exhaust leaking out, thats why it speeds up when your rpms go up. I have a couple broken bolts on my 6.0 been meaning to take care of it for awhile, also goes away once engine is warm.
*Just noticed you have headers, I know the stock manifolds really like breaking bolts, heard most people say headers are less likely to, still sounds like it could be a broken bolt though.
Old Feb 17, 2010 | 05:09 PM
chiliz666's Avatar
Yeah I'll check that out, on the driver's side a bold broke when the manifold was being removed, but no ticking, yeah ill check it and hopefully its just that.
Old Feb 17, 2010 | 05:14 PM
viciousknid's Avatar
Where's the Beef?
Not necessarily the bolt but the gasket. If it goes away when the truck warms up it could just be the infamous LS tick
Old Feb 17, 2010 | 05:22 PM
FERGHOE's Avatar
valves hiting the pistons...
Old Feb 17, 2010 | 05:24 PM
Where's the Beef?
So he just randomly dropped a valve and the truck still runs fine?
Did you use paper gaskets with the headers or re-use the stock manifold gaskets? If you used the paper ones that is likely the problem. Put stock gaskets back in it.
Old Feb 19, 2010 | 12:50 PM
chiliz666's Avatar
headers came with some thick gaskets bigger than the usual gaskets i see. If it is the gasket, you think I will be able to spot some soot?
Old Feb 19, 2010 | 01:00 PM
Mangled03gmc's Avatar
Baltimore Whore
More then likely its the gaskets.. ALWAYS reuse the stockers IMO, they are good... Also could be a lifter that has got dirt in it, not pumping up all the way, at first... Check the gaskets.. And we can't rule out the notorious piston slap, but would be weird why it would just start now.. Not a dropped valve
treylittlefield
Jan 24, 2016 07:38 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
superchomper2003
Aug 26, 2015 09:39 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
