ticking!!
Old Apr 25, 2006 | 11:23 PM
Coban's Avatar
I used a torque wrench. I also used loctite. The torquewrench I used was one of those cheapy $20 ones though. It clicks when it gets to the torque, no dial. Would they tick if they were over torqued?
Old Apr 25, 2006 | 11:30 PM
white1's Avatar
It will click AT the torque setting, you can still keep tightning though, it doesnt stop, just clicks to let you know youre there.
Old Apr 25, 2006 | 11:31 PM
Coban's Avatar
I used the air technique and the piston technique. (I didnt take a one way valve out of the hose coupler and there was no pressure in the cylinder at all. I got totally lucky that the piston was there to catch it. Strangely enough, the valves were held up quite a bit just by the seal.
Old Apr 25, 2006 | 11:32 PM
Coban's Avatar
I do know that. I was just telling what kind of torque wrench it was.
white1's Avatar
Originally Posted by CHEVY6000VHO
I'm just curious because "my" turn is coming up. How do you guys replace the vavle springs without the valve falling down into the cylinder?
Raise the piston all the way to the top or using a threaded air hose fitting in the spark plug hole, using the compressed air to keep the vavle from falling?
Jim
I turn the engine to TDC do two cylinders (two will be at TDC at the same time) rotate 90* then do two more, etc etc. You can line up the cam dots for #1 and ??. I used to know what 2 were next, but now I just stick a rod down the spark plug hole and see if the piston is up, or not.
Old Apr 26, 2006 | 09:14 AM
Coban's Avatar
Could someone give more information on the collapsed lifter issue?
Old Apr 26, 2006 | 12:37 PM
FarmerBeau's Avatar
Sexy Party Mod
Means the lifter isnt pumping up all of the way with oil. Im not sure how to fix it....other than pulling the heads and replacing the bitch. What causes a collapsed lifter?
Old Apr 26, 2006 | 01:09 PM
Last Call's Avatar
TOTM: January 2007
How many miles?
Did you change the oil pump?
Old Apr 26, 2006 | 01:26 PM
thunder550's Avatar
High on diesel fumes
I have heard that if you put a new higher lift cam on old lifters that it can cause issues. I had an intermittent tapping issue for awhile too, would come and go, and eventually it went and never came back. Mine would start tapping while cruising on the freeway or whatever, but as soon as I brought the engine back down to idle it would go away.
Old Apr 26, 2006 | 01:29 PM
thunder550's Avatar
here's my old thread about it
https://www.performancetrucks.net/fo...hlight=tapping
