tick tick tick, now what
Old Apr 5, 2004 | 02:05 AM
Ryan23silverado's Avatar
Yup, detonation fries plus in no time. A bad plug will cause misfires -especially noticeable at idle. Check all of the plugs like Flyer said. You probably melted one
Old Apr 5, 2004 | 10:04 AM
bigguy75inches's Avatar
well... this morning, the tick tick tick was very soft, i could barely hear it. so i let my truck warm up, and same thing. so i tried a test, i pulled a spark plug wire to see if the tick tick tick was still there or not. well, when i pulled the farthest plug on the driverside, i dont think i could hear the tick tick any more. so i pulled that plug, and it looked fine. so i switched plugs with the cylinder next to it. im kinda pissed now, cuz i can barely hear that tick... maybe after i pull that trailer to work, it will return. then i can do the test again to see if it switched cylinders. anyways, ill go ahead and get some new plugs just to be safe. oh yeah,, its rather shocking when you pull a plug wire off a running engine!
Old Apr 5, 2004 | 11:27 AM
LOW2000's Avatar
Keep in mind that you are probably getting non-audible detonation that will do just as much damage over time.
Old Apr 5, 2004 | 02:50 PM
ya I bet
Old Apr 5, 2004 | 09:08 PM
im reporting miss fires only at idle for cylinders 2 and 7, and sometimes 3. any thoughts? And can someone tell me the firing order of the engine ,,, or rather,, just tell me the number of cylinder starting from the front drivers side and going tward the rear
Old Apr 5, 2004 | 10:52 PM
front left (driver's side) are odd numbered pistons. From the front(fan) to the back (firewall) it goes: 1,3,5,7
front right (pass. side) are even numbered pistons. From the front(fan) to the back (firewall) it goes: 2,4,6,8
Old Apr 5, 2004 | 11:22 PM
Flyer's Avatar
I've been wondering that ...
It sounds like some plugs are burnt up.
Choda
Jun 5, 2025 06:43 PM
97_ek
Sep 23, 2015 09:16 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
lxcoupe
Jul 27, 2015 08:19 PM
chvy=power
Jul 27, 2015 10:06 AM
