free mods? and false knock ?
Old Apr 5, 2004 | 10:38 PM
getchusum99's Avatar
Question free mods? and false knock ?
i alredy did the egr inside the intake mod, and stupidly descreened my MAF , now wondertin what else i can do fro free that would help? also i have the 99 and somone said i could do something with the false knock or something like sauderin wires together to get more power, any help is appreciated.
Old Apr 5, 2004 | 11:03 PM
Hit Man X's Avatar
Ya can bypass the coolant going through the TB and make a restrictor plate for the EGR. Don't expect much but it'll give ya something to do. hahaha
PM 99silver5.3 about false knock. You need to be 100% sure it's false knock (which it probably is) buy running some 100+ octane gas on a stock timing table. If it's false then you'll need to solder in some resistors into the knock sensors to desensitize them. Not too hard but Jared's truck runs a lot better with that fixed and now that it's flashed with the '01 spark table.
Old Apr 5, 2004 | 11:45 PM
where do i get that high octane stuff from and also , do i have to put it on a computer or sumthin, where are the sensors? how would i do this.. im not dumb just confused, new termanology.
Old Apr 6, 2004 | 12:01 AM
Hit Man X's Avatar
Make your own... Toulene or Xylene and 91+ gas. ~4 gal of 91+ and 1 of the booster. Should be in the 97-103 octane area depending on what you use to boost the octane count.
You're gonna need some scan tool to check Knock Retard. It'll probably be like 8*. Once you have a tank of that high octane crap and you got KR on stock timing tables you'll have to solder in some resistors. That's all I can really tell ya as I never knew about the KR on my old '99 Z71 and now roll an '01. It's a pretty simple fix I know, you may have to pop the intake manifold too.
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
Pimpinpete
Sep 8, 2015 07:39 PM
Stainless Works
Sep 3, 2015 08:31 AM
