Throttle response....?
Old Aug 27, 2009 | 08:05 AM
00_Hotrod's Avatar
Default Throttle response....?
I have a friend thats got a 2005 1500 5.3 w/ electronic throttle & and an HP tuner he's adjusted timing and fuel & played with other things But the Throttle response still seems lazy, Does anyone know what to adjust on an HP to make it a little more responsive....
Old Aug 27, 2009 | 12:13 PM
andrew383's Avatar
traveling mod
does he have the current beta version?
the current beta has a new table for the "electronic throttle"
Old Aug 27, 2009 | 12:27 PM
00_Hotrod's Avatar
That were not sure of, we do find things like ETC high accel rate 5.0mph & low accel rate 2.0mph are these things that be adjusted for response..?
Old Aug 27, 2009 | 01:14 PM
terravast4's Avatar
My 05 was the same way but when I switched to the 90mm response was a lot better especially at part throttle.
Old Aug 27, 2009 | 01:50 PM
BlackGMC's Avatar
Resident Retard
Have you dialed in your VE and MAF tables with a wideband? I have GREAT throttle response and i have never messed with the ETC tables.
Old Aug 27, 2009 | 02:44 PM
00_Hotrod's Avatar
No he does not have a wideband, now he did descreened the MAF would that effect the response & also idle seems lower could that cause it...?
Old Aug 27, 2009 | 03:09 PM
BlackGMC's Avatar
Resident Retard
IMO I would never descreen the MAF, I am sure GM put it on there for a reason, probably to accurately read the incoming air... Also I have been told by a board tuning sponser
that you need to retune for a descreened maf cause the readinga will be different.. Tell him to get a wideband..
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 04:22 PM
99bluefirebird
Sep 17, 2015 08:05 PM
