Throttle Response....
Old Sep 6, 2004 | 08:04 PM
Get some 3.73 or 3.90's, along with a custom tune from Nelsons. The sluggish feeling is TQ management. Nelsons will eliminate some of it making driving a lot funner
Old Sep 6, 2004 | 08:28 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
When I installed my electric fans, it felt like the throttle was more responsive.
Old Sep 6, 2004 | 08:32 PM
superchargedchevy02's Avatar
I would go with MTI tune since your closer to houston than sanantonio
Old Sep 7, 2004 | 08:50 AM
SITNLO's Avatar
OK.....If i get a Nelson Tune.....will I be able to upgrade it when I get my 408 in a couple years?
Old Sep 7, 2004 | 09:32 AM
zippy's Avatar
tune will help, but a new converter will certainly help as much.
Old Sep 7, 2004 | 11:16 AM
STOCK_SUCKS's Avatar
Does Anybody Know Why The Throttle Response Is So Bad At Idle I Can Get On The Gas And Back Off Before It Revs
Old Sep 7, 2004 | 02:26 PM
marc_w's Avatar
Originally Posted by SITNLO
I currently have a 4.8L with stock everything besides a 3.5" delta force 6" muffler.
What mods can I do to give it better throttle response? Seems kinda sluggish right now...
One thing that improved my off idle throttle responce was a set of good plug wires. That initial tip-in is pretty responsive, and it takes less throttle to get rolling along.
I also like the stock airbox for low down throttle responce... I tried a few different configs, and I just like the stocker with a paper filter, or a drop-in if you've got a few mods. (I didn't notice anything from my drop-in until I got the exhaust on - and then it was only just a slightly revvier feeling top-end when I'd wind out first gear).
The cam I just put in rev's real quick in park or neutral, and throttle responce is sharp above 1,500rpm. There are some other grinds that I'm sure would extened the power lower if you want to keep things close to stock feeling - just stronger.
Old Sep 7, 2004 | 03:07 PM
SITNLO's Avatar
Cool....what wires did you get.....I'm about to have to replace my plugs and wires....I am probably going to go with some ACDelco Iridiums and some MSD 8.5mm wires
Old Sep 7, 2004 | 03:33 PM
marc_w's Avatar
I've got MSD 8.5's on there now, and they work great... I had Taylors, but I kept breaking them when I'd pull them off the sparkplugs. They had weak crimps down there.
I've got those NGK TR55's, and I couldn't tell any difference with them - I just did it because everyone else was.
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 04:22 PM
99bluefirebird
Sep 17, 2015 08:05 PM
