throttle body requirements
Old Jul 28, 2009 | 12:24 AM
ahartz28's Avatar
the best thing to do is get a scan tool and with the engine OFF press the gas pedal slowly and close it slowly. watch the TPS% and the voltage if it bounces or voltage drops/increases replace it and the wires too.check the voltage at idle as well and WOT. it doesnt require any reprogramming if its a stock tb and can be replaced by itself..
Old Jul 28, 2009 | 12:32 AM
melon07's Avatar
yea I'll see if I can get ahold of a scanner..
thanks for the tips guys.. I'll keep you posted
Old Jul 28, 2009 | 12:48 AM
viciousknid's Avatar
Where's the Beef?
where are you located?
If in Central or NW Oklahoma I might be able to scan it on Friday
Old Jul 28, 2009 | 01:04 AM
melon07's Avatar
haha um...... Cedar Falls, Iowa about dead center in this corn field... I mean state
Old Jul 31, 2009 | 03:18 AM
melon07's Avatar
so I replaced the throttle body and cleaned the MAF. My idle improved and it doesn't want to die when coming to a stop.
HOWEVER, it won't shift out of 1st gear now. If I manually put it into 2nd it will stay in first and roll up to 3-4k rpms and then spike/slip above that
I did get it scanned and all my sensors are in working order.
Can this be a electrical problem? Didn't hook up a wire right or a bad fuse? All I can think of is the guy that rebuilt my tranny did it wrong
natejk
Nov 15, 2016 08:05 AM
kalikid06
20
Oct 13, 2015 07:37 AM
99bluefirebird
Sep 17, 2015 08:05 PM
jleews6
Sep 8, 2015 10:17 AM
bisqikss
Sep 8, 2015 03:35 AM
